4.10 gear
Old Jan 5, 2004 | 09:56 AM
tubage's Avatar
Car: 91 formula
Engine: 5.0tpi
Transmission: t-56
4.10 gear
I am preparing to do a 4.10 swap along with a t56 conversion. I am currently running a more or less stock 5.0 tpi. I feel that is'nt too much gear. Opinions seem to vary though. I would like some feedback to help me out with the right move. My t56 is .50 overdrive 6th gear.
Old Jan 5, 2004 | 10:04 AM
ede's Avatar
ede
i know someone that has 4:10 with a 305 tpi and 700r4 and loves it, you should be better off than he is with more OD gear
Old Jan 5, 2004 | 10:08 AM
tubage's Avatar
Car: 91 formula
Engine: 5.0tpi
Transmission: t-56
Thanks for that info. I curious also about tire spin or too much. I am also building a 350hp 350 currently. I'm concerned from reading that with that motor and gear it may be too much
Old Jan 5, 2004 | 11:02 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
4.10's are perfect for a 6 speed car.
Just get decent rubber out back and don't do high rpm clutch drops and you will be fine.
The only drawback with a high hp motor, 4.10 gears, and 6 speed is when you run the 1/4 mile you may have to shift to 5th gear.
We had this issue with my friends 99 SS, at about the 1000' mark I'd have to shift to 5th and the car would pull a little slower.
I think the best his car did was 12.04 @ 117mph.
Old Jan 5, 2004 | 11:09 AM
tubage's Avatar
Car: 91 formula
Engine: 5.0tpi
Transmission: t-56
Thank you. Those were my thoughts as to the et gearing. I figure it will still run good et's but I'm building it for a street car. My goal is exellent all around performance along with fuel economy on the highway. I believe it can be done.
Old Jan 5, 2004 | 11:16 AM
Zepher's Avatar
Oh, and the nice thing about 4.10's is if you are cruising on the highway in 6th at 60mph or so and want to accelerate you can just step on the gas. With 3.42's, you need to downshift to 5th or 4th since there is no pull whatsoever in 6th gear.
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
