Th 350 in a -86 Z28?
Old Jan 11, 2004 | 05:37 AM
Tobbe's Avatar
Car: Camaro Z28 -94
Engine: Lt-1 350"
I got a -86 Camaro with a Chevy 408" in front. I´ve "burnt" three "hot rod" th 700 trannys and now I´m aiming for a th 350 with a manual valvebody.
I know I have to get a 1982 driveshaft from an f-body, that I have to rebuild the crossover and build a braket there I can mount the torque-arm.
Has anyone some pictures of their th 350 installation in a 3:rd genner? Tips on a good installation is wanted.
Yours: Tobias P, Sweden
Old Jan 11, 2004 | 07:27 AM
ede's Avatar
ede
your drive shaft will work with the long tail shaft th350. buy a b&m pn 30299 and you won't have to make anything to bolt up the trans to the cross member or to mount the torque arm on the trans
Old Jan 11, 2004 | 08:13 AM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
the driveshaft for the short tailshaft th350 is exactly 3 in longer than your 700r...got mine from a junkyard
Old Jan 11, 2004 | 09:07 AM
jon_volk's Avatar
he said he already has a driveshaft for an 82 which is the correct lenght...just get either the hurst or b&m torque arm bracket and youll be good to go.
Old Jan 11, 2004 | 09:33 AM
Tobbe's Avatar
Car: Camaro Z28 -94
Engine: Lt-1 350"
Th 350
Thank you all for your quick respond
I've already started to build a bracket that is bolted on to the rear of the transmission using 3 of the 4 bolts that holds the last piece of the tranny. It´s a copy of the B&M design.
By using this kind of braket I still can use the original torque-arm.
Tobias
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Linson
Aug 31, 2015 04:52 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
