Might swap in a 4th rear, 2 questions....
Old Jan 11, 2004 | 03:20 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
From what i hear its a stronger rear, better gears, and it has discs instead of drums, it's also wider, how much wider and how will this affect my car since i have TT2's how much farther will they stick out with my current offset of 5.5 on 17 X 9.5's
Old Jan 11, 2004 | 04:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's not stonger. It's basically identical.
The 4th gen rear is a little less than 2" wider on each side.
Your wheels will look stupid. They will give it that ridiculous r¡cer "skateboard" effect.
Old Jan 12, 2004 | 10:16 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you have 26 spline axels the 4th gen rear is a little bit stronger, because they all use 28s. If you already have 28s then they are the same strength wise.
RB's right about the tires sticking out. It will look goofy.
Old Jan 12, 2004 | 10:49 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally posted by TKOPerformance
If you have 26 spline axels the 4th gen rear is a little bit stronger, because they all use 28s. If you already have 18s then they are the same strength wise.
His 91 has 28 splines as well.
Yeah, no way will the 5.5 backspacing work out right.
Old Jan 12, 2004 | 10:55 AM
91Z28's Avatar
Car: 91' Z28
Thanks guys !
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
