T56 Flywheel
Old Feb 5, 2004 | 07:41 PM
colonboy14's Avatar
Car: Trans Am
T56 Flywheel
Will the RAM "Small and big Chevy, internal balance, 168 tooth" flywheel, Summit PN RAM-1501 fit on my 1 piece RMS engine for the T56 swap?
Do I have to have the flywheel balanced with the engine, or will it just bolt up? Sorry, I've never delved into my tranny before.
Old Feb 6, 2004 | 10:00 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Do yourself a favor and just buy a brand new 1993 Z-28 six-speed LT-1 flywheel or find a used one in good shape and have it surfaced.
I bought a new GM flywheel when I put my six-speed in a couple of years ago.
Old Feb 6, 2004 | 12:36 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yes, that should work fine. The flywheel should be neutral balance, so it doesn't need to be balanced at all, let alone with the engine. The only time balance would be a factor would be some 383s and 400s.
Old Feb 6, 2004 | 12:53 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: T56 Flywheel
I don't think it will, I believe that that flywheel is for a 2pc rear main. I believe 1510 is the one for a 1pc rear main.
The bolt pattern is different.
check out
http://www.flatlanderracing.com/ramfly.html
Old Feb 6, 2004 | 01:02 PM
Yeah, that's the topic that needs to be addressed. Is it for a 2-piece or 1-piece rear main.
Also, you need a 153 tooth flywheel. A 168 won't fit inside the T56 bellhousing.
Man, why didn't that catch my eye the first time. No, this flywheel won't work.
Old Feb 6, 2004 | 01:58 PM
colonboy14's Avatar
Car: Trans Am
Thanks for the help
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
