Rear end Rebuild
Old Feb 18, 2004 | 04:36 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Rear end Rebuild
if someone could give me a step-by-step process on redoing my rear end it would be greatly appreciated. i just ordered my Zexel posi from SLP and i have my 3.23s sitting in the closet so i would like to know how to do this.
Old Feb 18, 2004 | 07:43 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Nearly impossible to do on the messaeg board. You need a slew of gear pattern pictures to even begin to describe it. Get the setup book from Randy's Ring & Pinion at www.ringpinion.com
It's the best book I've seen and it's free with gears or a master overhaul kit.
Old Feb 18, 2004 | 09:49 PM
92MaroRS's Avatar
any tips tho? i really would rather not pay someone to do it for me.
Old Feb 18, 2004 | 10:24 PM
92MaroRS's Avatar
also for the speedo gears. the gears i have came out of a V6 that had the 200r4 and i have the 700r4 will the speedo gears work? also what is the difference between the drive and driven gears for each ration. 2.73 and 3.23
Old Feb 19, 2004 | 05:03 AM
ede's Avatar
ede
do a search, see if you have the tools to do it with, if not you'll be spending a few dollars on tools.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
