Transmission swap needs help
Old Feb 19, 2004 | 09:54 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Ok, I'm looking to swap transmissions here in the near future. My questions is can I put in a non-ecm tranny into my car and still be able to use my electro speedo? The reason is I swapped engines and now using a carb. No more ecm. So my torque converter doens't lock up. Oh yeah its a 700r4 too. Is it possible?
Old Feb 19, 2004 | 11:15 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The 700R4 is a non-computer controlled transmission. All the ECU controls is the torque converter lockup. Its simply handled as a flag in the BIN of the PROM, which is a fancy way of saying that the computer is used as a glorified switch. You can buy or make a setup that will lockup the converter only in 4th gear and unlock it when you brake for non-computer applications. Do a search on this forum and you will find plenty of info on this.
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
mizz0313
Aug 12, 2015 06:45 AM
