T56 Mounts and Wiring
Old Mar 5, 2004 | 03:39 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Guys,
Im putting in the T56 in my 85 TA.Ive got a Spohn Xmember and adj torque arm.What gearbox mount should i use.I dont wany poly,just a standard one.
Also do i need to connect any of the wiring to the trans,I dont want reverse lock out or the neutral switch,Do I have to??
cheers
PM
Old Mar 5, 2004 | 04:21 PM
Flyersman29's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
i think i used the mount of the 4th gen xmember that came with my tranny setup.. altho your old one should work too. not real sure on that one tho. i would suggest doing the wiring. it's not hard at all. just put a power and a ground to the reverse lockout. and the neutral saftey switch hooks right up to the clutch pedal. take you an extra 30min if that and the job is done right
Old Mar 6, 2004 | 08:36 PM
89 RS W/ T-56's Avatar
Poly Mount, TOO MUCH VIBRATION..............Go with the LS1 tranny mount. I have the SPD crossmember, had to enlongate the mount hole a half inch.
Jeremys87
Jul 14, 2022 09:08 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
