Moser 9" housing...
Car: 1991 Camaro RS
Moser 9" housing...
What would this rear housing need to be a bolt in for my stock rear? I have a 91 RS that is getting a 455 Buick transplant. It has drum brakes at the moment. I need to do this as cheap as possible and use as many ebay/used parts as I can.
http://www.moserengineering.com/cata....asp?ItemID=31
"Part #: 7H9FBT
GM "F" Body Housing WITH Torque Arm Brkt
$585 "
"Part #: 7H9FBT
$585 "
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you get that housing with the TQ arm bracket, and the axles that go with it... you can then get a used/ production 9" to drop into it....
swap the U joint on the driveshaft to a "conversion" one that will mate the shaft to the 9" and you should be set.
thats the idea atleast... i would go that route, but i have other things i need to do first.
Car: 1991 Camaro RS
darwinprice
17
Oct 11, 2015 11:51 PM
