is my pilot bearing in enough?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive been, uhh, "tapping" it and it just wont go in any farther.
there were two in the clutch kit.. appeared to be identical... one was a bushing, the other a bearing... did i fug up and this one not fit or what?
and yea i know some of you prefer the bushing over the bearing, but i chose this once since its what ive seen used in the later OEM setups, and it seems to work for them without issue.
Car: 89 RS
Engine: 383 in building process
You've got a long way to go. Your throwout bearing, if I'm not mistaken, should be at least flush with the hole your "tapping" it into.
Car: 91 Camaro Vert
yanked it back out and looked at it.
there was a burr on it...
sucky quality control there... heh.
i had to goto the GM dealer anyway since i somehow lost a flywheel bolt.. (doh...) but i got a new one there and it went in like normal...
you know its a damn tight fit when a stupid lil burr wont let it go in...
sucky quality control there... heh.i had to goto the GM dealer anyway since i somehow lost a flywheel bolt.. (doh...) but i got a new one there and it went in like normal...
