TV Cable Adjusted Advice before i Leave
Old Apr 2, 2004 | 02:24 PM
jdrafke's Avatar
Well, i re-adjsuted my tv cable today because i repalced the throttle body. ??? is i followed the tech article. I pushed in the button and pulled the line all the way to the firewall as far as i could. then released the button and pushed the throttle to wide open throttle. It cliked like 7 or 8 times in the process. just making sure this is the proper way to adjust before i take it for a ride. Ps. it has a 2500 stall and vette servo would this make this adjustment need to be done any different? And how can i be 100% sure this is adjusted right
Old Apr 2, 2004 | 05:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is the proper way to adjust the TV cable. In regards to the 2500 stall and vette servo, I cannot say if that would have any influence on it or not.
Old Apr 2, 2004 | 10:48 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I am not sure if it makes a difference but on my carbureted car to adjust the TV cable you push the D shaped button and pull the slider (not the cable) out toward the front of the car all the way have a friend get in the car and press the gas all the way to the floor and slider the slider back up till it stops. I adjusted my car this way and runs/shifts great 1250-1500 light throttle and 4500 WOT.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
deracer
Apr 11, 2016 12:04 AM
Prodigious
Oct 4, 2015 11:20 PM
Hello, Michael
Aug 20, 2015 03:19 PM
