Corvette Servo cover won't come off
Old Apr 3, 2004 | 02:58 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I'm supposed to be pushing it inward, right?
I've got a prybar to it and it's not doing it's thang.
Old Apr 3, 2004 | 07:48 PM
LeftTurn1LE's Avatar
Should push in a little bit. There's a snap ring and a rubber seal. You might try rotating it to help unstick the seal. You'll have to lower the trans a little when it does come out, because it will hit the tunnel. Hope that helps.
Old Apr 3, 2004 | 09:23 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I had a bar on there really hard, and i don't think it will turn. The cover did not go in a single bit. I might try a metal rod and beat the hell out of it with a hammer. The damn thing WON'T BUDGE.
Once it goes in, theres the clip to remove (at the bottom?) and the O-ring... Then I remove the Xmemb and lower the tranny slightly (careful to the dist cap) and access it that way?
It SEEMS easy enough, but the hardest part is always removal. I've spent twice as much removing things that I have putting them back on! Case in point, I still havent gotten my stock LCAs off!!!
Old Apr 4, 2004 | 09:20 AM
FstBrd6point3's Avatar
careful how hard you hit that cover, it is only aluminum, and ya prolly dont want to crack it.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
