700R-4 to T-5 question
Old Apr 7, 2004 | 12:28 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
im considering swapping a T-5 in place of my beat 700R-4, and had a few questions...
first of all my 700R-4 has been slipping sorta bad for a while now, and i've tried to nurse it as long as i can but its starting to get worse, and is now starting to make whining noise(i dont knwo why, fluid is clean and up to correct level..)... i dont have the ,money to buy a new tranny; dont really want to put a used one in ( because i'd risk having the same problem and dont exactly have the 100-200 bucks to get one...), and dont have the close to 300 bucks to rebuild the one i currently have... so what i was thinking is i'll swap in the T-5 i have at my house...
the tranny's(T-5) out of a 2.8 V6 firebird, the things i dont know about are:
1.) will the bell housing/flywheel work with the 305 in my car?
2.) will the drive shaft match up in length, or will i need to swap that from the V6 donor car also?
3.) and how much work am i looking at here? is it gonna be similar to dropping the auto and putting in the stick??
( i already have my console and carpet out of the car)
also what about the clutch pedal...how much work???
any help would be GREATLY appreciated; i dont know how much longer my 700R-4's gonna last-its got over 140K on it
Old Apr 7, 2004 | 02:05 PM
Super Camaro's Avatar
Car: 88 Camaro
Engine: 5.8L 355ci V8
You will need a V8 bellhousing and a 305 flywheel. Not sure bout the driveshaft. I think the hardest thing will be putting in the clutch pedal.
Old Apr 7, 2004 | 03:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The V6 bellhousing won't fit a 305.
The driveshaft is the same.
The V6 transmission has a different input shaft so the V8 clutch won't work (one guy here about a year ago had a special clutch disk made that had the V8 disk and V6 splines).
The V6 transmission has different gear ratios, and weaker internals.
You're looking at a lot of work, and probably as much money as getting your tranny fixed.
Old Apr 7, 2004 | 04:05 PM
Car: 88 Camaro
You will have to use the V6 clutch disc. If you just have a stock or mildy built 305 it wont be a problem. I am going to be using a V6 clutch with my 300hp 350. Your T5 will be able to handle a 305. Unless of course you realy beat the crap out of it.
I paid $100 for my bellhousing, $75 for my flywheel, and $45 for my pressure plate and clutch. If you prefer to drive stick, then put the T5 in. If you dont realy care, get your auto fixed.
Old Apr 7, 2004 | 06:58 PM
Car: 91 camaro rs
helpful info!
thanks for the info guys, i think after loooking at the cost of the bellhousing, clucth, flywheel, etc...
i'll just take the time to save up the moeny and rebuild my auto and maybe get a nice stall converter(for the motor taht'll be installed in the fall: +/-350horse)
thanks alot for the suggestions/help!!
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
