Grinding on shifts, reverse
Old Apr 7, 2004 | 05:44 PM
shapeshifter's Avatar
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
Hi all~!
well when i put my car into reverse sometimes (mainly after i have it in neutral) it will grind. Almost like once its in neutral you can feel something start spinning and it grinds against it once you put it in gear. i dont know im a car retard. but learning! any help would be greatly appreciated!
-Luke
Old Apr 7, 2004 | 06:38 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I have had this problem for 100K miles.
To stop it I put it into 5th first then drop back into reverse. Works everytime. I guess that it stops or slows the spinning syncros enough to get in gear.
Old Apr 7, 2004 | 08:37 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah there is no synchro on the reverse so it will grind, put in any higher gear first before reverse.
Old Apr 8, 2004 | 04:03 PM
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
Great. Thanks a bunch to the two who replied
-Luke
F-body driver
Mar 6, 2023 11:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
