T-5 whines in 1,2,3 and what flywheel for a SJ 327
Old Apr 12, 2004 | 08:01 PM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
My t-5 whines in 1,2,3 gear...and what flywheel do i need for a small journal 327 and my t-5 to connect up with my starter..
Old Apr 12, 2004 | 09:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably needs a clutch gear, countergear, and all the bearings.
You need a 83-85 305 F body flywheel and starter, and you need to have a machine shop drill the late-model bolt hole in your block for your starter.
Old Apr 13, 2004 | 08:42 AM
Car: 84 Trans Am
is there an different starter i can use so i dont need the hole?
Old Apr 13, 2004 | 09:15 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
For the wining noise is one of the bearing. Usually the inputshaft bearing is going south. I never worked on 327 before but I think any pre-86 int balance and 153 teeth flywheel would work.
Good luck
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
