Rear disk brake question
Old Apr 19, 2004 | 08:46 PM
AJB-283's Avatar
Car: 89 RS
Engine: 383
Axle/Gears: 9 bolt 2.77
I have finished changing out rear ends for a limited slip 9 bolt with rear disk brakes. Old rear end had drum. Anyone point me in the right direction for a proportioning valve, manual or new onw for 4 wheel disk. I have a manual valve, but have questions on if it will work.
Old Apr 20, 2004 | 05:22 AM
TomSlick's Avatar
Car: 82 Z28
Engine: 350 .060 over
Transmission: th200c
AJB, What rear end did you use ? I have a 82 Z28 with a 10 bolt and drums. I'm needing to change it out for disk.
Old Apr 20, 2004 | 05:46 AM
AJB-283's Avatar
Car: 89 RS
Engine: 383
i had a 10 bolt with drums, now I have a 9 bolt with disk. Later I am going to change gears. I have 2.77 in now, I want to go to 3.73
Old Apr 20, 2004 | 06:13 PM
TomSlick's Avatar
Car: 82 Z28
Where did you get it ? And what car should I be looking for in the junk yards ?
Old Apr 20, 2004 | 08:01 PM
AJB-283's Avatar
Car: 89 RS
Engine: 383
I got it from a guy here on thirdgen. I had to drive a couple hours to get it. Cars that have it, I BELIEVE, are the fbirds and transams. They are the common ones, I think that a few camaros have them. go here to this link and look at the tech data. You are looking for the astricks on the right part of the screen. Hope that this helps you.
https://www.thirdgen.org/newdesign/tech/techdb.shtml
check your PM, you got mail
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
