Strapping the driveshaft to the yoke
Old Apr 19, 2004 | 09:38 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Quick question. I was driving the other day and blew the caps off the u-joint. They were essentially new as I have been bringing the car back from the dead and don't drive it much yet. After letting a mechanic/friend press in the u-joints this time (just to make sure), I find that when I put the driveshaft in, only one side will sit comfortably in the yoke. Essentially, I have to tighten down the straps to get the 2 joints to snuggle into the yoke together. Is the way it is done, or should both sides slip right in at the same time? If so, what's the problem and how do I know when the driveshaft is right?
Kevin
Old Apr 20, 2004 | 04:30 AM
ede's Avatar
ede
they don't just fall in , you usually need to use the bolts or straps to fully seat the caps. did you have the little clip things on the caps? can't really figure out how you'd lose the caps.
Old Apr 20, 2004 | 08:49 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I bought a new strap kit at the local parts store for $5. I had a vibration at about 60mph. I was driving the other day and the car did its normal vibration and then something just popped (LOUD!). I don't have the interior in the car so the noise was disconcerting to say the least. I thought I blew the rear. I made it home (I only went around the block) and when I pulled the driveshaft, one cap was completely gone (hence the flopping of the shaft), when I took the straps off, one cap was still stuck in the yoke. So who knows, maybe bad parts.
Old Apr 20, 2004 | 03:35 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you don't have the snap rings fully seated the caps can fly out, I have experienced this personally (about 25 years ago when I didn't know better). It sounds like the cap that flew off was the one held in by the strap. Did the bolts come loose? My brother-in-law forgot to tighten the bolts on his Mopar Race car, fortunately it only broke an ear off the pinion yoke.
Old Apr 21, 2004 | 05:45 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
It seemed that the straps were still OK - I bought new straps and bolts anyway. I still have a vibration at 60-65mph. I think I'm going to try a new driveshaft and see if that's the problem. I'm thinking that the vibration was stressing the ujoints. Does anyone know offhand if the shafts for manuals and automatics are interchangeable? I have a local guy parting out an automatic and could test out the different shaft easily.
Kevin
Old Apr 22, 2004 | 04:21 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
yep, you can use any driveshaft auto or t-5 or u can spring for a 4th gen shaft, you get a ls1 shaft and its aluminum
Old Apr 22, 2004 | 06:51 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I found a good deal on an LS1 - will the 3" shaft from a 99 TA fit? Are all the LS1 driveshafts the same?
Kevin
Old Apr 22, 2004 | 08:01 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
yeah, i was behind my friend in his 71 bird when his driveshaft came out because he swapped rearends, and the new rearend didn't have the saddles for the u joint to sit in, so without and clips ot keep it from moving, after a few quick runs to 60mph, it came out, ohh it was bad.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Sep 29, 2015 10:18 PM
92projectcamaro
Sep 29, 2015 07:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
