high mile 700r4
Car: 87 iroc
high mile 700r4
I was wondering if I should put a corvette servo in transmission, but it has 136,000 miles on it? Also, is it a good to put a b&m shift improver kit that high of mileage? Where can I buy a corvette servo?
Transmission: 4L80E/4L80E
That's a little less than the mileage on mine when I did similar things.
I wouldn't suggest the B&M kit. No one around these parts tends to recommend them.
Try http://www.pro-built.net . Dana will set you up with what you need.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
glad to hear that cause Im about to put in a Transgo HD kit from Dana and my tranny has 135000. When I got the car with 74000 I didnt really get on it til I started going to the track and that has only been 4 times. other than that I take it easy with the tranny and the car. So mine should be ok for a kit install. I hope!
