S10 700r4
Old May 4, 2004 | 11:39 AM
andy86RS's Avatar
Car: 86 Camaro
Engine: 2.8
S10 700r4
I found a used transmission in a wrecking yard out of a S10, I am waiting for a call back on what year it is. I'm I wasting my time with this? My car is an 86 2.8 700R4. Can I swap the brackets and speedometer gear to make it work. I know about the torque bar, can the trans. mount be removed for it. Sorry for all the ? but this is the first time for a major part change. My Dad is making me do most of the leg work on this so any help will be apreciated. Thanks Andy
Old May 4, 2004 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You may be able to swap the extension housings between the transmissions to retain the torque arm mount; as long as they're the same overall length.
Other than that, it should bolt right in.
Old May 4, 2004 | 01:12 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Make sure the S10 has a 2.8 V-6 in it. A trans from a 4.3 V-6 won't bolt to your 2.8L.
Old May 4, 2004 | 01:15 PM
andy86RS's Avatar
Car: 86 Camaro
Engine: 2.8
Thanks, 75.00 is hard to pass for one that is working good. does anyone know what the factory stall is for my car. I want an inexpensive TC?
Old May 4, 2004 | 01:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A 6-cyl will stall one at around 1200 RPM or a little less. The one in the S trucks will stall a little higher, maybe 1400-1500 behind the 6-cyl.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
