I need help...PLEASE ALL TRANSMISSION AFFICIANDOS COME IN
Old May 4, 2004 | 05:06 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
My transmission is actin up...everyone come in
please dont tell me to do a search and stuff...i have no time for that
i treat my transmission pretty well...i dont neutral bomb it or anything. the only thing i do when im drivin is let off and then stomp it to downshift for more power...like when im passing or something. today i went to pass...and it wouldnt go.
from a stop it will go through 1st gear til about 4600 and then stop there until i let off...the engine sounds like its bogged down at this time. if im at half throttle its fine to shift through the hears. but if im in D...and i stomp on it, it will downshift to 2nd and stop at about 3000-3500 rpms...until i let off. i can barely do over 60 like this. i dont know whats wrong. I checked the TV cable...and its ok. the fluid smells a little burnt but nothing terrible. please guys give me some answers.
i will be taking it to an ac delco shop tomorrow to have them install my headers-back exhaust, so therefore it will be on a lift. if i get answers from you guys i can tell them to do more than just the exhaust, and have them fix whatever is wrong. if it helps, i had the fuel pump replaced about 3 weeks ago and the 02 sensor done a few months ago. the transmission fluid was done at around 55,000 miles, and now im at 57,150. coolant too. had a tune up at 55 thou as well.
Old May 5, 2004 | 08:10 AM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
Come on can't someone help me?
If it helps, this morning when it was cold, i adjusted the kickdown cable, and took it out to school. She ran perfectly until it got warm. Then it began doing what i described previously. The shifts were hard when it was working right. I dont get it.
Old May 5, 2004 | 08:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like something internal has failed, probably a lip seal on a clutch pack.... I doubt you're going to be able to fix it without a more or less complete rebuild
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
