what rear do i have and a speedo question
Old May 6, 2004 | 06:51 PM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t700r4
hey, the previous owner said that he had put the rear end of a 89 iroc on my 91 z28. how can you tell what ratio you have. I have the casting number that is on the housing. i believe that it is 22522676, but i cant really tell that the 6's are 6's. they may be 8's. and my speedo question. my electronic speedo does not give correct speed cause of the rear change. how do i get it to give correct speed. thanks
bryce
Old May 6, 2004 | 09:52 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
If its out of a 89 iroc it could be anywhere from a 2.73 to a 3.42. They had different gears depending on the model (350/305 Auto/Manual Etc...) One way you can tell is this, Use jackstands to get both rear wheels off the ground, get under the car and with a white marker or something, make a mark on the driveshaft where it meets the rearend and make on mark on the actuall rear end, then line the two marks up, now get someone to assist you, roll under the car and have your buddy turn the rear wheel one full turn and count how many times the driveline turns. Ex. if the drive line turns about 3 and a half times, you have a 3.42, if its turns less than 3 time, your a 2.73. Etc... Hope this helps you.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
