If I decide to keep my car I am leaning towards a T56 swap.
The roads really suck around here, and while my Iroc will not be a daily driver anymore, I am wondering if I will bottom out everywhere I go?
I heard the ground clearance on the t56 crossmember sucks. This is not good, defently since I scrape the front of my car almost everywhere (with new struts installed)!
What do you guys think?
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
The front of your car scraping isn't going to be any more of an issue with a different trans.
If you are concerned about ground clearance b/c of the aftermarket crossmembers, modify a stock one or do something custom.
-Matthew
-Matthew
-Matthew
I know a different trans will not change the scraping in the front, just trying to point out how bad the roads are around here.Originally posted by jmd
-Matthew
I was just wanting advice on how to get the most ground clearance out of a t56 swap.
