how do I get the piston and servo out
Old May 9, 2004 | 10:48 AM
Brandony'sZ28's Avatar
I got the cover off and the e-clip washer and spring out. I cannot however get the servo and pistion to move in the housing. Any thing would be helpful.
Old May 12, 2004 | 08:43 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
What are you working on? If its a 700R4 you will have to use air pressure to blow it out. Don't point it at your face when you do it either, that one might hurt a little
Old Jun 3, 2004 | 02:52 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
here's a jpg with instructions
Old Jun 5, 2004 | 02:48 PM
Pro Built Automatics's Avatar
When the cover exposes the blue cover sealing ring, pull down on the seal qith a scribe, and cut it and pull the seal out, now everything will come out easy.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
