10 bolt build-up
Subscribe
May 12, 2004 | 05:54 AM
I bought this car last year and it can be assumed that the stock rear is still in the car, that being a rear from a 88 SC 2.8, that being 3.42 gears, No posi and drum brakes.
My question How far can I go on a 10 bolt build up, what parts should I really be looking at and could somebody please show me some URL's. *first person to show a link to a 12 bolt or 9" deserves a kick in the *****
Reply 0
May 12, 2004 | 06:14 AM
28 spline axles, posi carrier, gears of your choice, install kit, solid sleeve instead of crush sleeve, weld axle tubes to center section, rear cover girddle
Reply 0
May 12, 2004 | 07:11 AM
https://www.thirdgen.org/newdesign/tech/ scroll down to "miscellaneous"
Reply 0
May 12, 2004 | 03:22 PM
Wow that's amazing I never thought a rear end buildup could be so cheap, I was for a time cosidering changing over to 9 bolt because I've heard a lot about how solid they are, but then I started reading more and realized how expensive and hard it is to get parts so I opted out.
I'd still like to see the specs on a built 9 bolt vs. a Built 10 bolt though.
Reply 0
May 12, 2004 | 03:31 PM
so for someone who has a newer axle with 28splines aready in it...
posi carrier (with new bearings)
rear cover girddle
Reply 0
Subscribe
