Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
ARP Exhaust Header Bolts
Old Sep 3, 2015 | 10:57 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
So far I'm really liking these 6 point, 8mm bolts. The one's that SLP supplied were 12 point? Well those were a pain to install and remove due to the design of the headers. And one bolt that I had purchased for the really tight #1 cylinder pipe, took me almost four hours to remove and bent up my valve cover in the process of removing it.
The ARP bolts went in smoothly, and the design of the 6 point, 8mm bolt head made it really easy for installation. They do come with with washers for every bolt in the package and I did have to use one or two but not all of them for the hole variations on the headers themselves.
Old Sep 3, 2015 | 03:14 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: ARP Exhaust Header Bolts
part numbers? what SLP headers do you have? the ones with the long standoffs?
Old Sep 3, 2015 | 03:36 PM
MY87LT's Avatar
Car: 1987 Camaro LT
SLP 30001. 1 3/4" with the A.I.R. tubes.
Stand offs? You mean those extension type tubes about 1 1/2" long welded to some of the mounting holes on the headers?
Old Sep 4, 2015 | 08:03 AM
86iroct5's Avatar
yes those.
what are the part numbers for the ARP hardware. i have mine rigged for now since i bought them without bolts i would like to do the ARP hardware, sounds like they fit very nicely in the tight spaces.
Old Sep 4, 2015 | 12:36 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Here are three pictures. One is of the ARP bolt package with the part number, the picture with the bolt using a washer is where I removed this extension piece SLP welded onto the header which my car has no use for. The one without the washer is the #1 cylinder exhaust port where it was a pain in the butt to remove the old bolt but easier with the new.
Keep in mind, I have the original stock factory heads on my car.
Attached Thumbnails ARP Exhaust Header Bolts-20150904_101743.jpg   ARP Exhaust Header Bolts-20150904_101558.jpg   ARP Exhaust Header Bolts-20150904_101619_001.jpg
Old Sep 4, 2015 | 02:54 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Same thing but not stainless...they are chromoly
http://www.summitracing.com/parts/arp-100-1109
Old Sep 4, 2015 | 03:21 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Yea they had those at Team C as well where I bought mine. I just went for a brighter looking bolt. Trying to brighten up my engine compartment.
Old Sep 7, 2015 | 08:09 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Talk about a nightmare removing the old bolts. Driver's side is complete and also found out I had a couple of loose spark plugs. I just worked on the right side and also discovered some loose spark plugs. I didn't finish the last two on the #8 pipe. I'll try to finish up tomorrow before it gets too hot out and tighten up the rest of the spark plugs. The sweat and pain will be worth it after it's all done.
Old Sep 19, 2015 | 03:32 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Finished with the bolt installation. I hate the numbers 6&8. It was a pain to finish the last bolts and tighten up the spark plugs. I did ruin the #6 spark plug wire and now have to order a new one. With that being said, onto the next project.
Old Sep 19, 2015 | 05:01 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The SLP bolts I have uses a 12pt 5/16 or 3/8s head but I like to use 1" long 12pt bolts and put a dab of anti-seize on them.
Have you measured your primary tubes? By looking at the cast flanges you most likely have the smaller 1 5/8s headers. (sucks but I ordered 1 3/4 headers back in the day but got the smaller ones. I have yet to find a 2 1/2 inch Y pipe other than the few prototypes) You will like them tho.
Obviously the standoffs are for the factory bolts.
I have modified a few wrenches for the header bolts and one for the plugs. I have the headers down to an hr or so for removal or install.
Old Sep 19, 2015 | 07:22 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I don't recall ever measuring the tubes but like you, I ordered the 1 3/4" with the y pipe ending at a single three inch (this pipe I did measure and is 3") to the cat. I ordered my headers around 98 or 97?
Old Sep 19, 2015 | 10:12 PM
TTOP350's Avatar
I bought my 1st set (and rest of the kit) back in 91 or 92 and all the sets i've seen/had though the yrs have the smaller tubes with the cast flanges. I was hoping to find a set of large tubes with the cast flanges for my collection
Old Oct 11, 2015 | 04:16 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by 86iroct5
yes those.
You'll need three diff. length bolts....I did. Measure EVERYTHING.
Old Jun 7, 2016 | 09:47 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I need to correct myself. Turns out my headers are actually 1 5/8". I checked them today with a digital caliper. Bummer. I always thought they were 1 3/4" ever since I ordered them.
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Aug 25, 2015 12:54 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
