New poly transmission mount adjustment?
Old May 15, 2004 | 08:04 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I installed a new ES poly transmission mount yesterday since my old mount had a tear in it. It now chirps the tires in 1-2 shifts, =). My question is the mount had slotted holes in it and I had to shift it all the way towards the passenger side for the bottom hole to line up.
Does it matter if it's not lined up perfectly from left to right?
Joe
PS. I had to use a file in the cross member hole so that the new bolt would fit. =)
Old May 15, 2004 | 10:37 AM
ede's Avatar
ede
doesn't matter, that's why it has slots. if it matter where it was located it'd be dowelled in place.
Old Jun 21, 2004 | 06:33 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I also noticed when I did mine yesterday (removed my jegster torque arm) that the ES mount is 1/4 taller due to the plate it comes with. THe instructions say, the plate is for pre-load.
Would you think the 1/4" hight difference changes the pinion angle?
-- Joe
customblackbird
Aug 15, 2021 10:16 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 5, 2015 07:57 PM
