shifting late and extremely hard
Old May 27, 2004 | 10:21 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
This afternoon i was stopped at a red light. I accelerate lightly and instead of the tranny shifting at like 2250ish nice and smooth, it won't shift. So i keep givin the motor a little gas and it revs all the way up to 3500 and then BAM shifts into second like i got hit by a car. It wasn't pulling the car along from like 2500-3500, just increasing revs. Same thing with the 2-3 shift. Beore this started happening it shifted firm and awesome.
The tranny was just rebuilt with a shift kit and corvette servo, also a new 2300 stall torque converter. This is no older than 2000 miles.
Old May 28, 2004 | 04:59 PM
chad89ta's Avatar
its not your trans,its the cable linkage.turn the car off then open the hood with your hand open the thottle all the way,there will be a little botton you press in to set the cable that runs to your throttle to your trans,if you cant get working right ill send you a picture to fix the problem
Old May 28, 2004 | 09:48 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
As chad89ta said you need to adjust the TV cable.
The cable is most likely adjusted too tight causing it to shift too late.
Old May 28, 2004 | 11:12 PM
chad89ta's Avatar
also if you set it to loose it will cause the trans to slide into gear,you dont what this to happen cause then you can do damage to the trans,but dont sweet it its an easy fix,and i beat you anything this is the problem
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
