problems with 9 bolt rear swap from 86 to 87 firebird - need help
Old Jun 14, 2004 | 01:34 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
my friend has a 86 firebird - which he uses for parts - the rear has disc brakes and a posi - so he wanted to swap over to his 87 firebird one peg leg car
after straight swap - the left wheel wobbles seriously wrong at very little speed -
we thought axle must be bent but really do not know - there are no ugly or squeaking noises like bearings
he now wants to take it back off - and put on original one peg leg rear end
only thing is - he first thought he would swap axles and tried to remove small retainer bolt for the crossshaft in differential -
it broke leaving unthreaded part of retainer bolt for the shaft stuck in cross shaft -
so we cannot remove axles or c-clip as the shaft is stuck in place on original one peg leg rear
QUESTION 1: can we re-insert threaded portion of retainer bolt (it screws back in without any problems) for the crossshaft to retain pin portion in crossshaft as originally intended and put one peg leg rear back into operation?
QUESTION 2: where to start looking for problems with wobbling left wheel analysis on 9 bolt rear?? I hear this is a good rear end and we would hate to not be able to make use of it in future
Wheels are in good stead - so its not the wheels itself - thats the first question I asked
Thanks for any help
Old Jun 14, 2004 | 02:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. It was a bad idea in the first place. 9-bolt and 10-bolt axles are completely different. They don't interchange.
2. The wobbling is almost certainly a bent axle. It's real easy to do that; a surprisingly light curb job is all it takes.
3. Yes you can put the remains of the screw back in and it will probably be OK.
Old Jun 14, 2004 | 03:47 PM
Engine: 383ci chevy
Really ?
So they do not interchange! they seem the same length
I am sure he will kick himself when he hears that!
Is it the spline count thats different or the carriers itself that makes the difference or both?
I checked the engagement of the rest of the retainer bolt thats left in the carrier and the shaft seems firmly in place even without threaded portion engaged
So I will tell him to put on some heavy Loctite and swap the peg leg back into service
Old Jun 14, 2004 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are altogether totally different. WAY beyond little details like spline count. For example, the 9-bolt doesn't even use C-clips; it uses a pressed bearing and a botled retainer plate.
Yes they are about the same length, as they do have to fit into the same cars. So that's a similarity. And, they have the same sort of flange on the end, since the same wheels bolt to them. The similarities end right there. Everything else about them is COMPLETELY different.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
