700R4 only downshifts one gear at WOT
Old Jun 16, 2004 | 11:29 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I just installed a new motor and trans. I am using SLP runners and a vortec base plate. The trans was rebuilt at a local trans shop. The shop has done several performance transmissions for me in the past. He will probably help me tommorrow, but I thought I would get some opinions. I have adjusted the TV by pressing the D button and sliding the plastic back into the cable and then cranking open the throttle and letting the cable ratchet to position. The motor seems to pull well, but I think I would have some more pep if it downshifted two gears instead of one. I tried the trans in the car before I took the old motor out and it worked great with the stock l98. Could the new torque curve on the 383 be throwing things off? Any help would be appreciated.
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
