Put an LS1 rear on the Formula
Old Jun 29, 2004 | 01:49 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I put an LS1 rear end on the Formula the other day with 3.73 gears. It doesn't stick out too bad with the stock GTA wheels.
The gears made a vast improvement over the stock 3.23 gears, as well as the LCA Relocation brackets.
I just need to put the calipers and new brake lines on soon, I don't feel that safe driving with only front brakes.
Also need to do something about the speedo since it's reading quite high.
Here are a few pics,
Old Jun 29, 2004 | 04:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Good looking ride. polish your taillights, though.
Old Jun 29, 2004 | 07:25 PM
Zepher's Avatar
thanks.
The lights are polished, they just have dust all over them.
Old Jun 29, 2004 | 10:39 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i'm was also contemplating the ls1 rear swap. it loooks like it doesn't stick out as much as i had orginally thought. great pics btw. i believe i will do the swap as soon as i get some stuff out of the way.
Old Jun 29, 2004 | 11:01 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
If thats as much as they stick out then I may do that for my car later on instead of rebuilding my 9-bolt with PBR calipers.
The only reason I'm reluctant to swap is because I like the light weight of the 9bolt, and I love the PBR rear brakes. But with an LS1 disc rear end I can get the brakes at least, and a decent posi that can be rebuilt much cheaper than a 9-bolt.
Old Jul 1, 2004 | 09:54 PM
transam84's Avatar
anyone know what kind of power (torq) an LS1 rear end can handle??? I got a line on one the other day and I was a little curious about how strong they are since I was originally planning on a Ford 9 incher.
Old Jul 2, 2004 | 12:11 AM
Zepher's Avatar
They are weak since they are pretty much the same as the ones in our cars., just a bit wider with newer brakes.
Get the 9".
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
