Rear End Going Bad?
Old Jun 30, 2004 | 03:11 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Rear End Going Bad?
My car has always had this washy, slightly grinding, sound coming from the back. The other day my friend grabs the driveshaft where it connects into the rear end and moves it around. There was alot of play. He said it might be going bad. Does the wierd sound support this idea?
Old Jun 30, 2004 | 03:14 PM
ede's Avatar
ede
maybe, maybe not you really need to inspect the internals of the rear to know for sure
Old Jun 30, 2004 | 03:15 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Your pinion nut could be loose. Does it whine more with or without throttle? Or the same all the time?
Old Jun 30, 2004 | 03:42 PM
Car: 1988 Camaro
Engine: 350 V-Eight
The faster the car is going, the faster and louder the noise is.
Old Jun 30, 2004 | 06:45 PM
Car: 1988 Camaro
Engine: 350 V-Eight
The sound is alot like front wheel bearings when they need replaced.
Old Jul 1, 2004 | 12:09 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
it might be the pinion bearing
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
