Grr, one thing after another
Old Jul 6, 2004 | 09:33 PM
Faded's Avatar
Car: '91 Firebird
One of the bolts that holds the pressure plate to the flywheel busted off while I was setting it to the right torque setting. So now I have half a bolt stuck in my flywheel and I have not a clue what to do to get it out.
It looks like this one bolt was a lot less heavy than the other bolts, and that's why it busted at only 40 ft/lbs.
Old Jul 6, 2004 | 09:52 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
can you get vise grips on it with the pressure plate off, if not youll have to use a drill on it, the have tools for this, you might have to tap a new hole
Old Jul 6, 2004 | 10:10 PM
Faded's Avatar
Car: '91 Firebird
Haha. Yes, that was pretty simple.
I took the flywheel off and was able to get it with some vice grips.
Old Jul 6, 2004 | 11:28 PM
Engine: 350ci
score!
about the new bolts, these bolts im told are special bolts they have a shoulder on them that lines the pressure plate up better, i just reused mine cause i didnt have the patience to get new ones but i wanted to, it was recomended by many guy to get new ones though, they are specific bolts though, just to let you know, where to get them i havent much idea, if i recall some guys said summit, but i might shout at gm see if they have new ones.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
