Shift linkage retainer clip.
Old Jul 12, 2004 | 06:01 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Does anyone know where to get a replacement clip for the trans cable retainer. (700r4)
This is the clip that holds the shift cable to the trans.
A friend needs a new one for his 1984 T/A. It became brittle and cracked (and the trans cable fell off the trans, leaving it stuck in gear).
Thanks for any help.
Old Jul 12, 2004 | 06:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a clip there? Everything should be bolted.
Old Jul 12, 2004 | 07:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The cable is actually held to the shift lever on the transmission case by a nut. He might be referring to the bracket on the tranny case that holds the cable or the plastic piece on the cable that holds it to the bracket.
Old Jul 12, 2004 | 09:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The bracket on the case is mounted by two of the pan bolts. Anything plastic down there that would get brittle and break is part of the cable and is replaced as an assembly.
Old Jul 12, 2004 | 09:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I know that and you know that, but he may not know that.
Old Jul 13, 2004 | 07:28 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Yes, it is the piece on the end of the cable.
So it looks like the cable will have to be replaced.
Thanks.
Old May 11, 2009 | 08:10 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Shift linkage retainer clip.
Hey everybody. where do I get a Linkage retainer clip. I need a brand new one. I went to the dealship and bought the shifter bracket, and a new shifter cable, but no retainer clip? WHERE PEOPLE. i know they had to make one for every car out there. THANKY people. Im sick of wasting time on google, what a joke
racereese
Oct 3, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
