Which 5th gear in my 87' LB9?
Subscribe
Jul 15, 2004 | 04:49 PM
I found the chart below in the tech data section of this site. I have an LB9 but since there are two listed here how can I tell which one is in my tranny. BTW ther tranny is out of the car at the moment and won't be going back in. I have an interested buyer but he was curious what the ratios were so I said I could find out.
1987 5-sp Warner Gear
LB8 4.03 2.37 1.50 1.00 .76
LG4 2.95 1.94 1.34 1.00 .63
LB9 2.95 1.94 1.34 1.00 .63
LB9 2.95 1.94 1.34 1.00 .73
Hodge
Reply 0
Jul 15, 2004 | 05:32 PM
Easiest way to tell is by putting it into fifth gear, marking both the input and output shafts and making a refence mark on the case for each one. Then spin the output shaft around one complete turn, and see how far the input shaft has turned. If it went approximately ¾ turn, you have the .73:1. If it only went about 2/3 of a turn you have the .63:1.
Reply 0
Jul 20, 2004 | 02:05 PM
Re: Which 5th gear in my 87' LB9?
Quote:
Originally posted by Hodge
the tranny is out of the car at the moment. I have an interested buyer but he was curious what the ratios were
There's a metal tag bolted to the tailhousing. Post the numbers from it.
Reply 0
Jul 20, 2004 | 11:05 PM
hes got G92 so its the .73
Reply 0
Subscribe
