Help!!! need to what cars came with a 700 R4 Trans
Car: 1986 T/A
Transmission: 700 R4
I have an 86 T/A with a 350 carb my transmission will go in to the passing gear but will not come back out the sometimes when i go in to passing gear it feels like my i am in neutral and my temp goes up bc my engine is high revingcould anyone give me a list or tell me what cars came with my transmission
:hail:
:hail:
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Off the top of my head are Astro vans, S10 trucks, Corvettes and RWD Caprices. However, I believe the 700R4's which had V6's in front of them have smaller input shafts.
All F-bodies from '83-'93 came with 70OR4 transmissions. Well...not ALL of them....but if you wanted an auto you got the 700R4 if you know what I mean.
From what I've learned here, the "best" 700R4's are from around '88 thru '93. The ones that came with the auxillary valve bodies.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You will have to get a 700-R4 from a thirdgen though because of the torque arm mount. None of the other GM car’s that it came in that I know of will work.
Car: 82 z28
Engine: 360
tranny doesnt have to be outa camaro u can use your tailshaft with traking arm mount from what i understand all v8 700r are same van truck except for tailshaft
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the corvette 700R4 mounting is in a different spot. you cannot use the corvette one. i don't remember specifically if it is too far back or moved forward.
bigjay89gta
Oct 15, 2015 08:04 AM
84 TA NV
Sep 6, 2015 08:02 PM
