Messed up my Diff!
Old Jul 24, 2004 | 05:34 PM
gonzo350's Avatar
Messed up my Diff!
I was in the process of replacing a bent axle. Had the diff open, removed the pinion shaft retaining screw, tapped out the pinion shaft, pulled the c-clip, and the axle came out no problem. I did some brake work, and when I was ready to put everything back together, the gears that pinion shaft go through...had moved. The pinion shaft hole does not align with the gear hole! How do I resolve this? When I spin the wheel, everything rotated together. This is a posi rear on 90 IROC. HELP!
Old Jul 24, 2004 | 06:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Take the gears out and realign them. I just did this a couple of weeks ago when i swapped to a posi diff. You might have to take the diff out though, which is really easy and takes less then 5 minutes.
Old Jul 24, 2004 | 07:01 PM
gonzo350's Avatar
Got it.....blocked one wheel and SLOWLY turned the other and got everything back into alignment....whew...
THANKS!
Old Jul 25, 2004 | 01:32 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah sorry thats how i did mine too. I took my posi diff out 4 times while i was setting up the gear pattern, so i got pretty good at it. I would have my brother just wiggle the wheel back and forth slightly till it slipped in. Glad you got it
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
