flywheel stuck need help !!!!!
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
hey guys i'm foing my clutch right now and my flywheel is the only thing holding me back from putting everything in again, how do i get tose 6 bolts off without an impact gun or air ratchet?
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Are the bolts too tight or is the problem that the flywheel is turning?
Is the motor in the car?
Turning flywheel
A tool is made that will hook a tooth on the flywheel to provide opposing resistance when loosening the flywheel bolts.
This makes it easy.
If the trans is moved away from the motor, can you use a bar to hold the flywheel still, using a bellhousing alignment pin as a fulcrum?
Tight bolts
longer wrench?
They are tough without an impact wrench. Hope you find something that works-
S-D
Turning flywheel
This makes it easy.
Tight bolts
longer wrench?
S-D
Car: 4
Engine: 6
Transmission: 5
Use a breaker bar and a short socket, and impact it rather than pulling on it.
You can also stick something through one of the holes to catch on the underside of the block or something.
monte87cortez
Sep 26, 2015 08:10 PM
