700 r4 over drive down shift
190 M.P.H. !!!! 700 r4 ????
ive heard that there are kits to keep trans from down shifting,but only to 3/4 throttle ...is it possible to hook lock up solinoid and forth gear solinoid to a switch so it wont kick down no matter what in order to reach the highest top speed possible .... thanks tao
82 recrao ta 350 cid (fixed) 293 posi 1700 rpm 4th gear converter locked up its doing 75+ mph
( hoping for 190 mph)
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You can setup the 700-R4 to not kick down to 3'rd but you will need to manually shift it into drive every time you want to downshift on the highway. This topic has been beaten to death do a search and you will find tons of info.
You can modify the TV plunger sleeve with 2 Allen plugs and a dremel. You need to block the 4-3 part throttle downshift holes. This should (in the majority of cases) solve this.
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I think what your saying is that at WOT your 700R4 won't upshift. Right? If thats the case order GM Upshift Kit #8673948.
Auggie
Auggie
right auggie ... with a little feathering of the throttle we can get 135 to 140 mph but then it shifts down into 3rd ... somthing is going to break if this keeps happening ... thanks for the advice all ... tao
1992 Trans Am
Aug 8, 2015 08:16 PM
