TCC selnoid, manual switch, etc
Old Aug 10, 2004 | 09:07 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Well, tomorrow i'm having my TCC selenoid replaced and was curious about somethings.
I hooked a test light to Terminal F on the ALDL port, then grounded the light, the bulb lit up. I then hit the brakes and the bulb went out. This would mean that everything electronically should be functioning as it should correct?
For a manual lockup switch, you connect a splice from terminal F(TCC) , and a splice from terminal A (Ground) to two connectors on the switch, when the switch is filled, it'll ground the connection forcing the TCC to engage and lock the convertor, am i correct on this also?
And one more, if a switch will simply ground out the terminal, would this be the same effect of having a paperclip between terminal A and F on the ALDL connector? The same way you'd read codes from the computer?
Thanks in advance.
Old Aug 10, 2004 | 09:13 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you want to do this, you would put a switch at the wire to pin "F" or somewhere in the wire that goes to it and then run a wire to a ground such as the chassis. You do not want to run a ground to pin "A" of the ALDL since that is the ECM ground and could cause problems.
Old Aug 10, 2004 | 01:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Isn't pin A grounded to the chassis anyway?
Old Aug 10, 2004 | 01:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, it is grounded to the back of the right hand cylinder head.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
