Question about 700 transmission.
Old Aug 25, 2004 | 12:34 PM
cjmelendez's Avatar
Car: 82 trans-am
Engine: 305 4bbl q-jet
I was at the mechanic today and said something that I had never heard before, he said my transmission was just a straight 700 not a 700R4. I did not know that there was a difference like that or that they were 2 different transmissions and I can't find anything about it online. Is he correct or is he full of it?
Thanks everyone.
Christian
Old Aug 25, 2004 | 01:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If your car is a 82, and has the original transmission in it, it's a 200-C (C is for "clutch", the lockup one); not a regular 200, not a 200-4R. It's not any kind of 700. There's no other kind of 700 besides the 700-R4; they changed its name later to the 4L60, and then the electronically shifted version is the 4L60E, but there's only one kind of "700".
Old Aug 25, 2004 | 01:19 PM
cjmelendez's Avatar
Car: 82 trans-am
Thanks RB83L69. You are right the car had a 200c but just got it switched for a 700r4. But the speedometer was reading about 12 or 15 mph above the actual speed so I needed to change my speedo gears. I took the car to a mechanic this morning and said that my tranny was not a 700r4 it was a 700 I told him I had never heard of that before that a 700 is the same than a 700r4. But he got me wondering that's why I decided to ask in here.
Thanks again for the info.
Chris
Old Aug 25, 2004 | 07:17 PM
cjmelendez's Avatar
Car: 82 trans-am
If I swapped my 200c to a 700r4. Do I really need to change my speedometer gear ration. Or do I use the same I had on the 200c. I'm keeping the same rear end which has a ration of 2.73 and the tires are 215 65R15.
Thanks to everyone in advance.
Chris
Old Aug 25, 2004 | 07:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The speedometer gears are in the transmission. Whatever transmission you put in will probably have the gears for whatever gear and tire combination were on th evehicle it came out of, unless you change them.
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
