th 200c transmission
Old Sep 7, 2004 | 10:19 AM
Jeff Morgan's Avatar
Have a problem. I have a 1982 pontiac firbird S/E with 305. Saturday my transmission seemingly stopped working. However, I was able to limp the car home. It goes into gear, but will barely move, and of course the engine revs while this is happening. I thinking the transmission is shot, but I going to have it looked at anyway. Could it by the torque converter or something elsel, or maybe the clutch packs are gone. Any help or suggestions are appreciated.
Jeff Morgan
Old Sep 8, 2004 | 11:47 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
These transmissions are well known for being junk, which is why they only lasted 2 years in Third Gens. Your best bet is to get another tranny type altogether. Even if you have the 200C rebuilt, it will still most likely cause problems down the road.
Old Sep 8, 2004 | 01:27 PM
kevinc's Avatar
Car: 1982 Z28
Mine had a TH200C when I bought it, it failed and I swapped in a TH700-R4.
Very easy swap and worth the trouble. You need the donor car's trans crossmember, transmission, torque converter, torque arm mount, driveshaft, torque arm, shifter cable, throttle valve cable, and shifter.
Only modifications I had to make to the car were drilling the rear holes for the crossmember in my frame rails, and fitting the shifter to the trans tunnel. The torque converter clutch lockup plug on my '82 harness plugged right into the TH700 connector without modification, pinouts and hoods were identical.
If you go this route, be sure you get a trans with cable-driven vehicle speed sensor. The later 3rd gens used magnetic and it's a hassle you'd rather avoid. Mine came from an '88 RS.
Old Sep 8, 2004 | 01:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I posted yesturday, guss I turned the computer off a tad quick after.
If it goes dead and you have no movement in any gear that would be from a dead converter or a fraged front pump. If it slightly moves forward your in need of a rebuilt (clutches slipping).
Last time I checked they were going for $500 rebuilt so you might consider using somthing else.
Replacing your TH200c with a short shaft TH350 would be a nearly direct swap excluding the tq arm kit that would need to be ordered. The kits run from $80+ and nearly everybody makes them. That would keep your factory shifter intact and give you a much more reliable transmission with the factory untouched look. Now if you were to go with a 700R4 you would need a new shifter and the glass indicator peice with OD. Its been a while and I cant fully remember every detail but I had to hax0r the one cable that goes back up to the coulmb and locks the wheel and the OEM 4 speed shifter dident line up with the factory bolts.
It was a swap well worth the time and money but I'm much happier with my current setup.
Old Sep 8, 2004 | 02:10 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
exactly what he said, except they were only in 82 IIRC
Old Sep 8, 2004 | 02:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Although the TH700-R4 was introduced in '83, the TH200C was still available. '84-up all automatics were TH700-R4.
Old Sep 9, 2004 | 01:19 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
gotcha.. never knew that
Old Sep 10, 2004 | 09:23 AM
Guys,
Thanks for all of your input. I have a TH 350 in my wrecked 86 bird, which I will remove this weekend. I'll replace the 200c in my 82 with the TH 350 from my 86. Hopefully everything will go smoothly. My 86 has the B&M shifter in it, and I may try to put it in my 82, but I'm not sure if it's a direct fit because the consoles are different. What do you guys think?
Jeff Morgan
Old Sep 10, 2004 | 02:35 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
with the b&m you may have to cut up your console..
Old Sep 11, 2004 | 10:52 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Originally posted by Jeff Morgan
Guys,
Jeff Morgan
If the 82 is real nice I wouldent bother with the B&M shifter. I personally would rather use a stock shifter then an aftermarket unit especially one that doesent fit correctly and needs to be adjusted every 6 months. One the other hand the entire console could be swap'd over and it would fit like it's suposed to.
Old Dec 1, 2005 | 07:41 AM
82knightrider's Avatar
Transmission: TH200C....700R4
any updates jeff...........
Old Dec 1, 2005 | 08:33 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
I thought I read that the 89 TTA had a 200 series tranny ?
Old Dec 1, 2005 | 11:40 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
consoles same
both are three speed autos, same deal, same length as the 200c if the 350 is 6" tail one(car or 69-72 truck one)
happy swapping
Old Dec 1, 2005 | 11:51 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Re: th 200c transmission
Jeff Morgan
Hi Jeff,
I noticed that your 200c is going.
Well, I'm upgrading my 200c to 4L60e.
My 200c is in great shape and has absolutly nothing wrong with it. I'm switching to the 4L60e to acheive better MPG with the overdrive. My 200c should go into your car with no problems.
I have scheduled the removal of the 200c the day after Christmas.
I do have a shipping container for the transmissin. An Aamco shop near me in Cary, NC is switching out the transmission. I can have the shop verify the condition of the 200c before it is removed.
If you are interested send me PM.
Old Dec 1, 2005 | 12:25 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
200R4, different animal than a 200C
Old Dec 4, 2005 | 01:01 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: Re: th 200c transmission
I'm sure he already took care of the problem since the thread is a year old.
Old Dec 4, 2005 | 01:11 PM
BruceEmbry's Avatar
Re: Re: Re: th 200c transmission
Ya I knew that after responing to thread. Want to delete, but for some reason Delete does not work!
Old Aug 15, 2006 | 01:52 AM
camber82's Avatar
um so if you go from th-200c to a th 350 it is really a direct bolt on? cuz my th-200c has no 2nd and since its an auto I can't skip it.
Old Oct 19, 2006 | 08:29 PM
BruceEmbry's Avatar
Hi,
This thread is old, almost 2 years. Anyway my 4L60e conversion went great. Absolutly no problems. Mileage went from 17MPG to 27MPG. Engine loves the gear ratio and overdrive. Car accerates like a bat out of hell.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
