1998 and up(LS1) T-56 onto an L98
Old Sep 7, 2004 | 12:13 PM
Yellow87Bird's Avatar
Car: 87 Formula 85 T/A
Transmission: 700-R4
My friend has a 1991 Z28 he's got the T-56 out of an LS1 car and was wanting to know some information. Whats all needed for this swap? Will the bellhousing work? Would you use an LS1 style clutch? THANKS in advance
Old Sep 7, 2004 | 01:24 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Bellhousing won't work. Input shaft won't work. Front cover plate on the transmission will need to be changed also. If you can find someone to sell you these parts off of an LT1 tranny, then it'll work, but you'll have to use LT1 clutch parts.
Then again, everything you have will work, if you swap in the LS1 to go with the trans.
Old Sep 7, 2004 | 06:48 PM
biff85ta's Avatar
Car: 04 Vette
It can be done just do a search on www.hotrod.com for the Mcleod modular belhousing.
Old Sep 8, 2004 | 10:58 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Actually it can be done with the stock T-5 bellhousing and clutch.
McLeod has the adaptor plate and special pilot bearing that is needed for the swap, but it does encompass some problems.
(1) You need to shorten the drive shaft 2" and the torque arm.
(2) The shifter will hit the console and needs to be bent forward.
(3) The floor board needs a piece cut out about 3" back.
(4) Then there is the speedo problem.
Other than all that it works, as I have done one.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
