700r4 strength?
Old Sep 13, 2004 | 07:31 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
700r4 strength?
Hi guys im looking for a 700r4 trans for my 83 camaro.Its a 5speed right now,are some of these trans stronger than others and what car did they come in.Theres a 88 WS6 formula at the wreckers right now i can scoop up just dont know if it week or not
Old Sep 13, 2004 | 09:38 PM
kd5boc's Avatar
Car: 92 RS
Re: 700r4 strength?
87 and up 700's were the better deals...just make sure it's not a bad trans...the 3-4 clutch pack tends to go out early.
Old Sep 13, 2004 | 10:09 PM
Car: 1983 Z28
Engine: 383
Ok its in a 88 formula firebird,im going tomorow to grab it.The cars also has a BW 9 bolt disk brake rear end posi 3.27 gears wich is gonna be tough to get out,the locking wheel nuts are on it so itll be a pain too get those tires off
Old Sep 14, 2004 | 12:34 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Also grab the driveshaft, TV cable, shifter and linkage, dipstick and tube, rearend, brake lines, prop valve, and have fun. What's the rear ratio currently in your car? 700's are fairly troublesome though, so pull the pan before you pull the trans and see what's at the bottom of it - some grey and copper is probably OK, but who knows - if it has fluid, give it a wiff for a burnt smell. A trans go shift kit will make your day though, and a little bit more stall speed will do wonders.
Old Sep 14, 2004 | 11:37 PM
Car: 1983 Z28
Engine: 383
Damm the cars a 85.I am just looking for a good core for my buddy to rebuild for me,we'll strip it right down and put new guts in it from B&M.They have those transpak's i think there called and come with all the goodies to rebuild.The diff i got today seems in good shape it a 3.27 ratio which sucks im looking for 3.73.I did grab everything with the diff,all the cables,driveshaft,proportioning valve and master cylinder.Tomorrow ill grab the trans and all the cables and the ws6 front sway bar.Musta been half a dozen guys stripping that poor car today,looked like a nascar pitstop at the local pickapart
Old Sep 15, 2004 | 12:35 AM
Do you mean the 88 is an 85? I don't think 85's came with a 3.27 borg warner rear. It may be a 3.23 GM 10 bolt though.
Old Sep 15, 2004 | 01:50 AM
Car: 1983 Z28
Engine: 383
Well the is marked as a 1985 and the rear end has borgwarner embose on it and the 9 bolt cover.So i think its say to say shes a niner
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
