4l60e install
Old Sep 28, 2004 | 10:05 AM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
4l60e install
besides the pcm issue. what is required to install a 4l60 in a 3rd gen? i have a sick project in mind and this is the trans i need to use.
also can the transmission internals be manipulated with a "performance shift" system like on the pontiac gtp?
Old Sep 28, 2004 | 10:57 AM
ede's Avatar
ede
should bolt right in if it's from a 4th gen f body.
Old Sep 28, 2004 | 09:35 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
what about the Computer controls though? I just scored one for buying the guy a burrito So I too am curious lol
Old Sep 29, 2004 | 01:57 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Use a ECM from a early-mid 90's pickup and you should be good to go. U only need the TCM side of things and have to splice in rpm/tps/etc but it has been done quite a few times alreadyn and lots of knowledge on it on the DIY -PROM board.
check it out and do a search.
later
JEremy
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
