350 carb or lt1?
Old Sep 29, 2004 | 09:00 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
350 carb or lt1?
ive got a 350 block sitting in my garage right now ready to build i want to put a top flow top end kit on it which will produce 500hp and 450ftlbs sould i do that or buy an lt1 and build from there?
Old Sep 29, 2004 | 11:08 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
The advantages of the LT1 motor are that u can run a little more compression and a more aggresive timing curve...
The motor is also reverse cooled meaning the water goes from the WP right into the head (colder water means more C/R and more timing) then into the block....you CANNOT swap heads from a LT1 to a gen 1 SBC...
so if that kit is for a SBC then it wont work on a LT1...not without extensive modifications
This is the wonrg forum for this BTW
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
