lighter flywheels?
Old Oct 1, 2004 | 06:46 PM
pitbullgst's Avatar
Car: 1st gen RX7
Engine: tpi 383 conversion in process
Transmission: b/w t-5 swap in progress
lighter flywheels?
Wherer can i find lighter flywheels for the t 5 transmission? i have searched and came up with pretty much zilch! can someone please point me in the right direction?
Old Oct 1, 2004 | 08:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
centerforce website. they have a list of all the common sbc flywheels. aluminum for one. but, be prepared even the steel ones are very $$$$$$$$
Old Oct 1, 2004 | 08:11 PM
Engine: ls1, LB9
http://www.centerforce.com/centerfor...tarq=CHEVROLET
you can use these part numbers at summit or jegs. most local speed or machine shops can get you prices too
Old Oct 3, 2004 | 01:11 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
www.sdpc2000.com they have a selection of aftermarket and GM
lite weight internally and externally balanced nodular iron (15lbs.) flywheels (tested to 10,000 rpm). I've been using one for many years with great results. Hope this helps
Old Oct 4, 2004 | 09:50 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Yeah, I really like my 15 lb. nodular iron GM flywheel, cost about $140 from Scoggin-Dickey, same as on DZ302 and other factory high performance small blocks--but it's for internally balanced two piece mainseal engines. For an externally balanced and/or one piece mainseal motor you're going to pay at least twice as much--but it gives the car a much quicker response that you can really feel.
Old Oct 4, 2004 | 11:31 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
14088646 Flywheel
Outside diameter is 12 3/4" for years 1986-up. Crank Flange bolt pattern: 3.00"; clutch dia.: 10.4", 11"; starter ring gear teeth: 153. Lightweight nodular iron flyweel. Weighs approximately 16 pounds. For one-piece crank seal.
just over $200 at GM Parts Direct
Old Oct 5, 2004 | 04:50 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Originally posted by 91formulaSS
14088646 Flywheel
I paid $75 for that one from a junkyard. It came off an '86 Vette. It was in great shape too.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
