Shift kit???
Old Oct 10, 2004 | 04:01 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Shift kit???
Well I am putting a 350 in my car real soon to replace my 305. The mechanic stated that I should put a shift kit on my 700R4. I asked him what it does. He said that it makes the shifts firmer. I don't quite understand what he means. Any advice on this? What does it do? is it worth it? Which would you recomend?
Old Oct 10, 2004 | 04:49 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Recommend a Transgo shift kit from Pro-built, comes with corvette servo, etc. Do a search here you'll find all kinds of info.
Old Oct 12, 2004 | 06:35 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Ditto,
I got the B&M kit, but from what I hear the transgo is a better kit.
The shift kit will make the tranny shift faster (not sooner) by applying the clutches with more psi and volume. This takes away the tranny's stock slushy shift and gives a firm or hard shift into the next gear. With a moderate amount of power, it will scratch the tires from 1 to 2 (when I got my 3:73 installed with the posi, I could get a good chirp out of both tires from 1st to 2nd with a stock LG-4).
Old Oct 12, 2004 | 06:54 AM
bigarmzz's Avatar
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
Re: Shift kit???
isnt a transgo for the overdrive tranny expensive?
i know a b and m shift kit fot the TH350 is only like $30
-bigarmzz-
Old Oct 12, 2004 | 03:34 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Trans Go i think is around 100 bucks. I had my TH-400 rebuilt for 800 bucks with a Trans Go shift kit and extra clutches.
Old Oct 12, 2004 | 03:45 PM
naf's Avatar
naf
If you're on a budget, consider the transgo jr (heavy duty) from Pro-built, comes with corvette servo for less than 100. Check their website.
Old Oct 12, 2004 | 03:53 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I've owned both the B&M and Transgo kits.
By far I like the Transgo a lot more. The B&M has a very harsh 1/2 shift due to a spacer that's installed... it always shifts harsh even at part throttle. I was always chirping the tires or breaking them loose in the rain (not fun in the middle of turns).
I still had a 2nd to 3rd gear flare up problem with the B&M (the trans would shift and jump up acouple 100 rpms between gears before going into 3rd).
The Transgo kit comes with more parts (reason why it's more expensive). The Transgo kit offers a nice shift, until moderate throttle then it firms up a lot. The Transgo comes with larger boost valve (more pressure), I don't think the B&M has that. Also the kit includes the corvette servo.
Overall in my opinion it's just a better kit.
As for Pro-Built their awesome to work with. Give them a call and they should beable to tell you all about the transgo kit.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
