Torque Converter Slipping
Old Oct 10, 2004 | 05:44 PM
barspin89's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
I recently switched my carb from the stock Quadrajet to a holley 600. The Rochester and the torque converter were computer controlled so it no longer shifts at the right rpm. Does anyone know a cheaper fix than purchasing a $160 lock-up kit
85 Trans Am
LG4 305
700-R4
Old Oct 10, 2004 | 09:13 PM
firebirrrrd's Avatar
The search button answers all:hail:
Old Oct 10, 2004 | 11:46 PM
onebinky's Avatar
The torque converter has nothing to do with shift points. More likely is that the TV cable is out of adjustment. The easiest way to adjust the cable is to depress the little "D" shaped button on the cable, push the little ferrule back in the housing all the way, release the button, then go depress the gas pedal all the way. It will self adjust, and your good to go again.
Old Oct 12, 2004 | 07:01 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Start here.
https://www.thirdgen.org/techbb2/sho...hlight=lock+up
and here.
http://www.highperformancecars.com/crosley/lockup1.htm
and here
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
