Shimming the carrier and housing
Old Oct 11, 2004 | 06:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have recently shimmed the carrier assembly. I think I used to much shim though. I ended up using .047 on each side. I went to put the carrier assembly back into the differential housing and check the wear pattern. I could not insert it with both original shims. Did I use too much to shim the carrier or is this usual? The carrier seemed to seat well with the spider and side gears. I set it up for street use only really. I used all new bearings.
Old Oct 12, 2004 | 04:48 AM
ede's Avatar
ede
that's only .094, most carriers i've seen have more like .2 to .25 shim per side. whatever total shim thickness you had when you removed it is what you should have when you put it back. how the shims are arranged from side to side is the only variable.
Old Oct 12, 2004 | 08:34 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Thanks ede, I guess I'm doing alright so far.
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
