Speedometer cable leak on a T-5
Old Oct 13, 2004 | 07:46 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Does anyone know if there is an o-ring or something that goes in that area where your speedometer screws in. Or is the bolt (screw thingy) that you tighten the speedometer cable up with supposed to tighten up and seal itself? Another thing does anyone know how to chase the threads on that piece that screws down? I think I might have some cross threading issues.
Old Oct 14, 2004 | 11:20 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if you crossed threaded it i wouldnt waste my time, get a new one i've seen them on ebay for around 7 bucks, the 10mm screw comes out with a clamp, pull the speedo housing out, their is an o-ring on it, but in any case, yes the speedometer cable nut has to be tightened all the way or it will leak
Old Oct 14, 2004 | 06:39 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
speedo cable
Thanks 86z for your post. I guess I will replace it and see what happens.
Old Oct 17, 2004 | 12:02 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
there is the o-ring on the outside of the sleeve, and there is a seal on the inside against the gear. Could be either.
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TrevinE
Sep 14, 2015 03:20 PM
DARKmj16
Sep 9, 2015 04:07 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
