Had rear gears changed last week and now I'm noticing a whining sound is this normal?
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Had rear gears changed from 2.73 to 3.73 thick ring and pinion. Stock 10 bolt. I'm noticing a whining sounds coming from rear end and the best way to describe it is it sounds like a police or ambulance sirene in the back ground that varys with speed. Is this normal?? Haven't had a chance to call the guy cause its the weekend
Engine: 4++,350 & 305 CIs
Yep, you should have a little wine nothing to crazy though..
whose gears did you use??? most aftermarket gears are cut for strength and the OEMs use a "quiet" type cut..
wanna play gotta pay
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Which gears did you use? Richmond whine. Ask me how I know.
If they are set up correctly there should be very little to no whine at all.
Car: 91 Camaro RS
Engine: 305 TBI
not sure the manufacturer of my gears they are a 3.73 thick ring and pinion. He told me they are set up very very good and that the whine is normal especialy when changing from a OEM gear to a performance gear. These are designed for strength not comfort.
Guy has a very good reputation. Here's his web site if anyone is interested. By the way these gears are only temporary for the Pro-built automatic I'm about to put in. I'll replace the rear when I break it or I can afford a Moser posi 12bolt. Whichever comes first. Performance Differential
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
As long as it doesn't get any louder it should be fine. But you should barely be able to hear it. If it's quite noticeable I would take it back and have it checked just to be sure. I once had this problem and it got progressively louder. I had to take it apart put a new crush sleeve in it and reset the pinion depth to fix it, this was on a Ford 9 inch.
Car: 91 Camaro RS
Engine: 305 TBI
it's real faint. At first I kept thinking a police car or ambulance was coming up on me. Thats exactly what it sounds like but real faint. I don't think theres anything wrong but of course I will always be aware!!
